Clipped FINISH Vs. FRAMING Nail - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-19-2008, 01:17 PM   #1
Rewards Points: 1,062
Question
clipped FINISH vs. FRAMING nail
awhile ago, someone advised me against getting a clipped head framing nailer because those nails are not legal in many municipalities. i got a regular one, makita, and it works great.
however, in the meantime i have also acquired a finish nailer
http://www.milwaukeeconnect.com/weba...oductId=735554
and it was not advertised as clipped head but a sample pack of nails that came with it are clipped, so i am assuming it is a clipped head nailer.
Q1: are clipped head finish nails subject to as much code scrutiny as framing nails
Q2: if anyone has experience with this particular nailer, do you know if regular head nails an be used with it (i am just throwing it in, i know i can call customer service to find that out)
Q3: any other opinions on this nailer ? i really like makita and milwaukee, they are my favorite US tool brands.
thanks,
- a -
Old 04-19-2008, 04:14 PM   #2
Res Ipsa Loquitur
Interesting- I have not seen a "clipped" head finish nailer.
I like Milwaukee power tools but don't know about their air tools.
I have a Porter Cable Framer with clipped nails and a Senco Finish nailer using full strips.
Even if your area is against clipped head nailers, I can't see how they would have a problem with finish nails- finishing nails are usually for decorative uses, window & door trim, base molding and similar uses. Framing nailers are mostly used for structural components in the framing of a building. Safety issues come into play.
Regarding interchanging nails, many air nail boxes list multiple use brands on the flap so that nail may fit others as well.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 04-19-2008, 08:04 PM   #3
Registered User
Termite's Avatar
From a code standpoint, there's no application that allows a finish nail in a framing situation. As stated, you're only going to use finish nails in trim applications, and the code is silent on fastening of trim. So, for trim, use whatever you like! I've never heard of a clipped head finish nail.
Old 04-25-2008, 11:18 AM   #4
I'm certain the OP is confusing finish nails, which do not have "round" heads at all, with the round heads found on framing nails.
They are actually entirely different beasts.
I'm sure he has a standard finish nailer.
Garasaki is offline   Reply With Quote
Old 04-25-2008, 03:46 PM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
amakarevic, where is that tool made?
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
buying a nail gun with compressor Dave777 Tools 9 11-27-2011 11:37 PM
Best Practices for Framing Nail size jms5883 Remodeling 7 01-31-2008 11:37 AM
Finish Nailer Help hiskid1973 Tools 2 04-17-2007 06:21 AM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 09:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
