Clearance For Double Oven Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 05:43 PM   #1
Steeler99's Avatar
Clearance for double oven installation
Just got off the phone with my father and he's reframing out a new opening for adding a double oven where a single oven with built in microwave above originally was.
He researched the clearances required and all he could find was that the oven needed to have 3/4" clearance when at the end of a run of countertops. I believe this is the side clearance.
My question is...the existing opening has drywall in it, which I would think should be cement board. Is drywall ok?
Also, the opening as it is now is 24" deep....which the existing oven was 22 1/2" deep. The new oven is 23 7/8" deep, leaving an 1/8" clearance behind. Is there a standard minimum clearance for a built in oven like this?
Steeler99 is offline   Reply With Quote
Old 01-30-2011, 06:16 PM   #2
Contractor - Renovations
fungku's Avatar
For the clearances it would probably be best to read the installation specs for that particular oven. You will be able to sleep soundly at night
fungku is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Is this a lousy granite installation? timbo59 Kitchen & Bath Remodeling 70 05-16-2013 11:08 PM
Gas oven problems gregsmy Appliances 1 12-03-2009 06:55 AM
oven installation captainmorgan Electrical 32 03-12-2009 08:42 PM
non-metal conduit for oven installation? Jeremy Hillary Boob, PhD Electrical 0 01-22-2009 11:20 AM
