Cleanup Woes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 01:52 PM   #1
Cleanup Woes
So my wife and I are almost finished with the demo for our bathroom remodel. One of the things that's very important to both of us is to keep our working environment clean and neat. A little more background.. we live on the second floor of an apartment complex. Because of this taking out all the drywall..tiles..cbu.. etc to the back where we have a "Bagster" set up is a really time consuming task. We have been trying to find out if there is any known methods for transferring the rubble with minimal strain. We have about 10 contractor bags full of junk at the moment in our apartment. It sounds much worse than it looks just because of how clean and neat we have kept the whole process.
So the question is, what is the best way to transfer the rubble? The Bagster is directly below one of our windows so we were thinking about a "chute" system.. anyone tried anything like that before and have any tips?
busyhammer is offline   Reply With Quote
Old 02-27-2013, 02:37 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,110
By the time you build a chute.....you could have those bags downstairs.
If you both do it...it's not hard.....and good exercise....
ddawg16 is online now   Reply With Quote
Old 02-27-2013, 02:59 PM   #3
Everything you said is true but do you know of any pre-made chute systems out there that don't cost thousands of dollars? Ive looked all over and cannot find something that was made for non-commercial use .. :-/
Old 02-27-2013, 03:31 PM   #4
JOATMON
ddawg16's Avatar
That is the problem. Either the project is small enough that the DIY'r does it by hand....or you pull in the big guns and pay the bucks.
In the time you have researched it....the trash could have been out....
The Following User Says Thank You to ddawg16 For This Useful Post:
kwikfishron (02-28-2013)
Old 02-27-2013, 08:39 PM   #5
Rewards Points: 150
It's called friends or relatives and a case of beet
kaschmid3 is offline   Reply With Quote
Old 02-27-2013, 08:40 PM   #6
Rewards Points: 150
I meant beer
Old 02-28-2013, 07:30 PM   #7
Rewards Points: 162
Does your apartment have an elevator? If so, I would use a 32 gallon plastic garbage can and purchase a garbage can dolly. Do a quick google search for "garbage can dolly" and you'll see some examples.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 02-28-2013, 07:46 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 436
You can buy sono tube in several diameters and about any length you want. Its cardboard tubing used for concrete piers and columns- quite strong. Check with concrete supply companies http://www.homedepot.com/h_d1/N-5yc1...avigation?lang..
Old 02-28-2013, 08:55 PM   #9
kwikfishron's Avatar
Rewards Points: 172
+1 on that ddawg16.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
joecaption (03-01-2013)
Old 03-01-2013, 08:42 AM   #10
Rewards Points: 3,130
Why not just tie a rope to the bags one at a time and lower them down through the window?
Tags
cleanup , rubble , trash
Exterior Lap - spray or roll and oil based cleanup wdpcpa Painting 8 12-15-2012 06:20 PM
Paint cleanup dmradulescu Painting 6 11-11-2011 11:29 AM
Disk Cleanup kwikfishron PC Repairs & Upgrades 23 09-25-2011 10:46 PM
Enamel Paint Cleanup dbower Painting 4 06-19-2011 04:27 PM
Cleanup after a compressor burnout Aptguy HVAC 10 08-23-2009 09:28 PM
