Cleaning Vinyl Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-16-2012, 05:36 PM   #1
cleaning vinyl siding
I tried to clean this off by hand using warm water and dish soap and even vinegar. Nothing will remove it. Pressure washer?
dinosaur1 is offline   Reply With Quote
Old 05-16-2012, 05:48 PM   #2
kwikfishron's Avatar
Rewards Points: 586
Post # 17 Vinyl siding, white spots?
kwikfishron is online now   Reply With Quote
Old 05-16-2012, 05:55 PM   #3
MarginallyQualified
Rewards Points: 2,464
replace the entire wall or at least from the window sill down.
That'll allow you to get rid of those vents too.
Old 05-16-2012, 06:05 PM   #4
Household Handyman
Rewards Points: 1,408
I see two (2) darker spots, a larger one under the windows, and another to the right of the electrical receptacle. This appears to be "sun spotting" as we call it around here. And NO, there is nothing that will remove these if this is "sun spotting". These are just one of the wonderful items that are built into vinyl (plastic by any way you look at it) siding. I have worked with plastic molding in my time and colorization throughout the material is rather tricky.
Old 05-17-2012, 09:35 AM   #5
DIY or die !
Rewards Points: 77
a slight bleach to water ratio with a sprayer works great. DO NOT pressure wash your house ! You are just asking for rot down the road...
lewisthepilgrim is offline   Reply With Quote
The Following User Says Thank You to lewisthepilgrim For This Useful Post:
dinosaur1 (05-17-2012)
Old 05-17-2012, 11:16 AM   #6
Rewards Points: 3,628
Go to Home Depot and get some Mold Armor E-Z house wash,comes in a green gallon container,follow the instructions on the container.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Vinyl siding over wood siding snorris1 Building & Construction 29 03-02-2012 10:23 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 07:06 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
