Cleaning Up A Contractors Brickwork - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-30-2008, 01:44 PM   #1
Cleaning up a contractors brickwork
Hi all, i'm new here.
I had a brick flower planter put in a couple days ago and the contrator didn't do a very good job on finishing the joints. They look ok, but a little sloppy for me. He didn't round them out either. I was at work when he was working on it, so i couldn't tell him to round them out until it was too late. Well, I don't feel like calling this guy back out to redo it so i wanted to just do it myself.
I have an idea of how to do this but need a little guidance.
How would i do this? What tools would i need? Thanks.
alex94z is offline   Reply With Quote
Old 05-31-2008, 07:37 AM   #2
normally brick jnts're 'tooled' prior to mortar hardening & they'd be concave (sunken),,, rounding 'em 'out' suggests convex which isn't common,,, which is it ?
yesitsconcrete is offline   Reply With Quote
Old 05-31-2008, 08:54 AM   #3
I want them to be sunken and rounded inward. Right now they are flush with the brick face. So i would need to remove some of the mortar with out damaging the brick. Excuse me for not knowing the correct masonry terms.
Old 05-31-2008, 09:07 AM   #4
IF you're VERY LUCKY, you might be able to hand-grind w/either rubbing brick OR thread'd rod.
glad i didn't add 'grapevine' to the types of mortar styles
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 07:04 AM
Choosing a contractor Grumpy Remodeling 7 04-28-2011 07:29 AM
Roof Cleaning before replacement.. RoofWarrior Roofing/Siding 3 05-15-2006 02:59 PM
