Old 09-17-2011, 03:07 PM   #1
Clean Polyurethane Self-Leveling Sealant Off Concrete
I was doing well sealing the joints around my cellar door when the back of the sealant tube blew out and dumped sealant on the patio.
Using water to clean it up seemed to make it worse. I dabbed up as much liquid sealant as I could. I was wondering what is the best way to get the rest cleaned up. Is there a specific solvent which is better to use?
Greg
gbeckowski is offline   Reply With Quote
Old 09-17-2011, 05:06 PM   #2
We use Glaze-n-Seal stripper,[black can]on all concrete to remove sealers.very powerful stuff.it will etch concrete serface as well.so be easy.use a chip brush 1.00 each HD has them.go to your concrete supply they will have 1/2 pint samples.READ ALL LABLE.glove up, it will burn.It might take 2 coats to remove polyurethane.leave stripper on 1 minute at a time or less it drys faster in sun.use water with stiff brush to remove all stripper,let dry completely befor 2nd coat if needednow you have a very clean small area of your concrete patio.you may have to put a sealer over the clean area now.if it is a texured concrete,stained patio it wont hurt the finish.just pressure wash all of patio,put a high end sealer over.good luck.ken
We all no alot but can onlydo a little-----an
kchunt is offline   Reply With Quote
Tags
clean, concrete, polyurethane, sealant, self-leveling
How to Score Concrete and keep things clean mobiledynamics General Discussion 2 09-17-2011 03:52 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Self leveling concrete questions Dave K Flooring 3 08-21-2011 06:49 AM
Leveling a concrete slab floor RICHARD HARO Building & Construction 3 03-05-2011 10:30 PM
Leveling concrete floor - problem McCool Flooring 3 12-05-2006 10:31 PM
