Clean Mortar Haze On Brick - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-09-2011, 09:37 AM   #1
Rewards Points: 39
clean mortar haze on brick
HI how do i clean the mortar haze off of new brick?
thanks
tiki16 is offline   Reply With Quote
Old 10-09-2011, 11:45 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...and this "new brick" is out of doors I suppose?
XXX
Old 10-09-2011, 11:50 AM   #3
Rewards Points: 6,652
thanks
Muratic acid or TSP.
Old 10-10-2011, 02:56 AM   #4
This haze you are referring to is salt coming out of the bricks. Clay depending on where it comes from can contain a great deal of salt and the only thing to really get rid of it is time. I had a wall with the same problem I just kept washing it with a hose every now and then. The salt is deep in the brick and will take time to come out. It happens quite a lot.
builder66 is offline   Reply With Quote
Old 10-10-2011, 07:23 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I would be more inclined to think the haze is coming from the mortar. It's a new job, it's very likely there is mortar haze on the brick from the striking and cleaning of the joints. That would be common.
Natural salts coming from within masonry is typically referred to as efflorescence and I would bet that's not what this is. Not right now anyway. Efflorescence doesn't appear in the form of a haze, efflorescence typically blossoms and blooms.
XXX
Tags
mortar haze brick
How do you remove mortar from brick? JAYinMA Building & Construction 1 09-17-2011 07:10 AM
Expansion / Contraction 2x4 whitewood studs on brick bpardo Building & Construction 2 08-29-2011 02:22 PM
covering interior wall with full size brick SydneyJames Remodeling 5 11-11-2010 04:54 PM
Spalling brick and mortar issue tiki16 Building & Construction 6 10-03-2010 09:11 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
