Cladding Wall Around A "Freestanding" Ventless 2 Sided Bio-ethanol Fireplace 6k BTU - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-21-2015, 05:40 AM   #1
Rewards Points: 434
Cladding wall around a "Freestanding" ventless 2 sided bio-ethanol fireplace 6k BTU
See the pic below for my project.
I am installing a double sided bio-ethanol burning fireplace into a wall cavity. Am I ok to use "X" drywall to wrap the frame above and below the fireplace recess (and the adjacent wall to the fireplace opening? The fireplace is rated at 6k BTU.
I don't want to tile over this area, so durock is not ideal (unless it can be finished out like sheetrock and painted). I'd like this whole wall to look continuous and seamless and it will all be painted same.
Here are the fireplace specs:
Burner type / quantity: 1 x 1.5 Liter Dual Layer Burner made of #430 Stainless Steel; BTU: 6,000; Flame 12 - 14" High; Burn Time: Approximately 6-8 Hours.
vestaviascott is offline   Reply With Quote
Old 03-21-2015, 09:39 AM   #2
joed's Avatar
Rewards Points: 12,914
What do the fireplace install directions say? I would think if wood is OK then then drywall should be fine.
Old 03-21-2015, 10:04 AM   #3
Rewards Points: 13,740
Not getting the way it's framed or how close it is to the wall.
Should have been framing and clearances needed right in the directions.
Can not imagine it being safe to have it that close to that right wall.
With it that close to the wall and not framed out on the left hand side how are you going to sheetrock it?
It's also weaker because there's no stud from the floor to the ceiling.
Basement interior block fireplace surround wall wall joeags Insulation 0 11-22-2013 11:36 PM
Wall damage below bathroom quaker87 Plumbing 8 02-28-2013 04:56 PM
What correct mix for building a stone foundation wall? & correct mix for stone fireplace. world travler Building & Construction 0 08-04-2011 06:39 PM
damp wall above fireplace puzzled Building & Construction 8 11-03-2009 03:26 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
