cinder blocks under tub?
My point is that even though the bottom of a tub might "appear" to have some flat areas, if you were to crawl up under there with a tape measure you would find that the bottom surface varies greatly. Embedding the tub into wet concrete settles firm support into all the odd shaped areas and the many out-of-level spots. And it is super simple to do.................
Ya buy some bags of sakrete, dump them into a 5 gallon bucket, add some water, and stir it all up till it's nice and thick. Then you just dump it into the tub area and set the tub down into the wet stuff.
Done.
Willie T
