#1 |
Cinder blocks not intersecting at corner of foundation. OK?
I should say, CONCRETE block ....
Hello, I tore a home down that I am now planning on rebuilding. Today while cleaning up, I noticed that at the foundation where an addition was done, the block from the addition does not meet up with or intersect in the corner and there is actually a small air gap. I am not concerned with the gap as I can seal and insulate it, however, for code reasons I want to make sure this is ok. The addition was not deep enough so I will be insulating from the exterior to get it to code but the intersection of block here is a concern. I have a drawing if this helps. On the left is the overall perimeter of the block foundation. It was a 24x24 with a 16x34 addition. There are footers under both sections and the work was done quite some time ago with no cracking so I feel that the foundation is very sound, just not sure if it is OK for code. I appreciate the help!
| Display Modes | |
| concrete over cinder blocks for foundation?? | Birdman79 | Building & Construction | 10 | 11-24-2010 02:32 AM |
| How to Repair Cinder Block Foundation Cracks | Germwise | Building & Construction | 4 | 07-01-2010 12:14 PM |
| heat loss through hollow cinder blocks | diy4life | Building & Construction | 11 | 11-19-2009 11:37 AM |
| cinder blocks under tub? | Leoskee | Building & Construction | 8 | 09-03-2009 05:52 PM |
| can i use cinder blocks for my floating deck foundation? | chinolofus | Landscaping & Lawn Care | 5 | 05-05-2009 01:46 PM |
