-   -   Cinder blocks not intersecting at corner of foundation. OK? (http://www.diychatroom.com/f19/cinder-blocks-not-intersecting-corner-foundation-ok-112390/)
mjjstang 07-29-2011 10:37 PM
I should say, CONCRETE block ....
Hello, I tore a home down that I am now planning on rebuilding. Today while cleaning up, I noticed that at the foundation where an addition was done, the block from the addition does not meet up with or intersect in the corner and there is actually a small air gap. I am not concerned with the gap as I can seal and insulate it, however, for code reasons I want to make sure this is ok. The addition was not deep enough so I will be insulating from the exterior to get it to code but the intersection of block here is a concern. I have a drawing if this helps. On the left is the overall perimeter of the block foundation. It was a 24x24 with a 16x34 addition. There are footers under both sections and the work was done quite some time ago with no cracking so I feel that the foundation is very sound, just not sure if it is OK for code.
I appreciate the help!
http://i5.photobucket.com/albums/y18...g?t=1311993186
