Cinder Block Walls Replace With Metal Post - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-03-2012, 11:12 PM   #1
Cinder Block walls replace with metal post
When I stripped down the basement I found three cinder block post/walls. I was wondering if I could tear them down and replace them with jack-posts. There is already a metal pose supporting the floor but i don't know if i need the rest.
The main support beam rests on the cinder blocks and post. The basement is 43 feet long and the blocks and post are approximately placed equally apart. The main beam runs into the exterior walls.
I do not know which of the posts are load bearing or not
Param is offline   Reply With Quote
Old 07-03-2012, 11:15 PM   #2
Pictures
These are some pictures so you can see what I'm talking about
Cinder Block walls replace with metal post-img285.jpg   Cinder Block walls replace with metal post-img286.jpg   Cinder Block walls replace with metal post-img287.jpg   Cinder Block walls replace with metal post-img288.jpg   Cinder Block walls replace with metal post-img289.jpg
Old 07-03-2012, 11:19 PM   #3
Rewards Points: 13,300
Your going to have to hire a real engineer for this one to come on site to check it out.
It would be nuts to suggest asking someone on any web site to guess on this one.
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
Working with cinder block tarie77 Building & Construction 19 09-08-2011 12:22 PM
exterior cinder block walls Bridgette Painting 2 01-09-2011 08:52 PM
Insulate Top of Cinder block wall HooKooDooKu Building & Construction 0 01-20-2010 11:58 PM
Tying in a 2"x4" walled-booth with a cinder block wall johnofthemount Building & Construction 3 12-19-2009 03:51 PM
