Old 01-19-2010, 11:51 AM   #1
Cinder block wall - filler
Hi,
I have a shared cinder block wall in my townhouse and am looking to stop sound from traveling up the wall.
My first thoughts are to drill a hole in each block and use an expanding spray foam. Any thoughts if that will work or if there is a better way?
Also, can you rent spray foam kits at home depot? I think I'd need the type that hooks up to 2 propane tank-like vessels. Any ideas on cost ?
Thank you
Chazz
chazz is offline   Reply With Quote
Old 01-19-2010, 03:35 PM   #2
General Contractor
I can't picture it, cinder blocks are usually filled with mortar, does that spray foam even stop sound? That is made for filling in gaps.
Only thing I can think of is to frame another wall with fiberglass insulation and soundboard attached, and a one inch gap from your bricks.
KennMacMoragh is offline   Reply With Quote
Old 01-19-2010, 03:58 PM   #3
concretemasonry's Avatar
"Cinder blocks" are NOT usually filled with mortar, but in some areas they are filled with grout, which is a big help since the mass is increased.
I saw not mention of of brick, but it is a shared townhouse wall.
Fiberglass batts are not very good for sound and other batts that are much better.
Foaming or caulking cracks is a big help if the wall is exposed, since sound does not just go up, but travels in all directions.
Dick
concretemasonry is offline   Reply With Quote
Old 01-19-2010, 04:01 PM   #4
Old School
Willie T's Avatar
That wall is possibly already filled with (depending on its age) vermiculite, perlite, or some other newer fireproofing material.
Willie T
Willie T is online now   Reply With Quote
Drilling cinder block? garyoutwest General Discussion 5 06-20-2009 01:33 PM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-09-2009 12:49 AM
Cinder block wall hangings shnfldr Remodeling 2 06-07-2008 09:26 AM
Knocking though breeze block wall gazza General Discussion 1 10-01-2007 08:42 AM
