Cinder Bloc Laying - How Many Wet Layers At A Time ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-21-2008, 08:16 PM   #1
Rewards Points: 1,062
Question
cinder bloc laying - how many wet layers at a time ?
i thought i could take a deep breath and erect an entire shed in one sitting (dimensions approx. 12 L x 10 W x 8 H) but then i though that the weight from the above may squish the wet mortar of the lower layers.
thanks,
- a -
Old 04-21-2008, 09:05 PM   #2
Rewards Points: 1,232
It won't. Lay the corners up, then fill in around, and you can lay it all at one setting (theoretically, of course).
Tscarborough is offline   Reply With Quote
Old 04-21-2008, 09:09 PM   #3
concretemasonry's Avatar
Rewards Points: 2,608
If you have the right mortar consistancy and are a relative rookie you can go up as fast as you can lay the block to a reasonable quality, even for a smaller job.
concretemasonry is offline   Reply With Quote
cinder bloc shed - fill or no fill ? amakarevic Building & Construction 3 04-16-2008 09:07 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
