Old 02-28-2013, 11:36 PM   #31
Choosing the right Nail Gun
Originally Posted by Mijotter View Post
ok whew. Ok so from all of this; 10d(3"), 10 gauge(.131) Smooth framing nails. Got it!
Same size but galvanized for treated lumber right?
Yes, that is correct.
framer52 is offline   Reply With Quote
Old 03-03-2013, 01:33 PM   #32
Exclamation
Thanks for all the help guys. My cousin already has a 4 gallon air compressor that runs 2.8 SCFM at 90 psi.
http://www.homedepot.com/webapp/wcs/...a#.UTOTRBy1k60
Will that be ok to use with;
http://www.harborfreight.com/air-too...html?hftref=cj
Mijotter is offline   Reply With Quote
Old 03-04-2013, 07:53 PM   #33
Exclamation
So all the nail guns I've looked at and wanted use clipped nails instead of full round. Does this matter when framing non load bearing walls? Will clipped nails be totally fine for this? Thanks.
Old 03-04-2013, 08:05 PM   #34
journeyman carpenter
woodworkbykirk's Avatar
clipped head nails arent accepted in many regions now because they dont hold nearly as well as a full head
woodworkbykirk is offline   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
hand drive (03-04-2013), joecaption (03-04-2013)
Old 03-04-2013, 11:24 PM   #35
It must be ok in my region because every framing nailer at my local home depot is for clipped nails.
Old 03-04-2013, 11:24 PM   #36
AHH, SPANS!!!
clipped head nails are especially not as good for sheathing applications. walls and such where mid nail span shear is more important the clipped heads do not matter as much.
hand drive is offline   Reply With Quote
Old 03-04-2013, 11:36 PM   #37
So for standard stud framing on non load bearing walls. Will clipped heads do the job well?
Old 03-04-2013, 11:39 PM   #38
AHH, SPANS!!!
sure, add a few more nails per piece to compensate...
Old 03-04-2013, 11:42 PM   #39
Gotcha. I'm having a harder time finding clipped head galvanized nails though, know of a place? Need 10 gauge, 3".
Old 03-04-2013, 11:45 PM   #40
Sorry what do you mean by mid nail span shear?
Old 03-04-2013, 11:46 PM   #41
For a simple basement remodel they will be fine.
Where they come into play is in hurricane or earth quake prone areas for roofing and sheathing.
woodworkbykirk (03-05-2013)
Old 03-04-2013, 11:50 PM   #42
AHH, SPANS!!!
where the shear pressure goes across the width of the nail and not the length of the nail where pull out happens.
The Following User Says Thank You to hand drive For This Useful Post:
Old 03-05-2013, 12:09 AM   #43
The wall will have a little weight attached to it in the from of a shelf for speakers, receiver, bluray player, etc. Will also be framing out a door as well to kind of give you guys a better idea of my project. I actually found a round head nailer sort of in my budget but can only order online so will have to wait 5-6 days. Sorry to keep asking, I just want to make sure i'm doing it the best I can. Should I wait for the round head nailer or just get the clipped head nailer so I can start sooner.
Old 03-05-2013, 07:53 AM   #44
AHH, SPANS!!!
clipped head nailers are on the way out the door like vhs, I'd wait and get a full head nailer. if you do another project years into the future you might not find clipped head nails available
Tags
framing, nail, nail gun, stud, wall
Me ranting about nails... Pittsville Building & Construction 14 10-05-2012 01:26 PM
Nail gun shock injuries dswan388 Safety 5 06-17-2009 01:21 PM
Nail gun shock injuries dswan388 Roofing/Siding 11 11-24-2008 07:34 PM
Nail gun shock injuries dswan388 Tools 5 11-02-2008 09:46 PM
Nail Gun Plastic Nail Casing frustrations smark General Discussion 6 07-07-2008 09:10 PM
