Choosing The Right Nail Gun - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 01:06 AM   #1
Rewards Points: 150
Exclamation
Choosing the right Nail Gun
http://menards.com/main/tools-hardwa...04-c-12912.htm
Would this nail gun be sufficient for framing my basement walls? I plan on using 10d 6.35cm framing nails and galvanized ones for nailing to the treated lumber. Or would a Palm Nailer like this work;
http://www.amazon.com/Stanley-Bostit...ds=palm+nailer
Mijotter is offline   Reply With Quote
Old 02-28-2013, 06:32 AM   #2
Rewards Points: 150
If u r going to use palm nailer might as well gammer. Those r really only good for nailing into tight spots were you can't get a framing or TiVo gun so I would def choose the framing gun
kaschmid3 is offline   Reply With Quote
Old 02-28-2013, 08:26 AM   #3
Rewards Points: 150
Ok awesome. So would the nail gun I linked work with the nails I had listed in this same post? If not do those palm nailers handle those framing nails I have listed in this same post?
Old 02-28-2013, 08:29 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
a cheaper nail gun will result in sooner failure. buy a good nail gun and you can sell it used later and make some money back, more if you take care of it while you use it. a palm nailer is more of a specialty nail gun for tight spaces etc... a standard nail gun is better suited for more purposes.
hand drive is offline   Reply With Quote
Old 02-28-2013, 08:42 AM   #5
Rewards Points: 150
I am not framing an entire house. Just a small basement project...so...would that nail gun i linked work with those nails I listed or not? If not will a palm nailer handle those same nails? Thanks.
Old 02-28-2013, 09:17 AM   #6
Rewards Points: 13,250
Forget about the palm nailer, it would be a pain to try and toe nail with, It would be very hard to get the nails started on an angle.
I agree with the other poster for a job that small a reguler hammer would make more since if that the only job you have for it.
By the time you buy the gun and the special nails for that gun you have spent more then it's worth.
If your building the wall laying down you need 16D, if your toe nailing you need 8D.
Only use nails marked ACQ approved for the bottom plate.
Just any galvinized nail will not work.
Mijotter (02-28-2013)
Old 02-28-2013, 09:25 AM   #7
Rewards Points: 150
Ok, I'm not trying to be rude or anything. But can someone just answer my question please. The one i've asked 3 times so far; Would the nail gun i provided the link for handle the type of nails i have listed? Thank you.
Old 02-28-2013, 09:36 AM   #8
Yes it will work, going to also need at least a compressor that can put out 3.5 CFM to run it.
Old 02-28-2013, 05:26 PM   #9
Rewards Points: 150
Thanks a lot. And sorry, will it work with 16d nails as well? Also, it says it's a clipped head nailer, do i HAVE to get clipped head nails?
Old 02-28-2013, 06:59 PM   #10
Rewards Points: 3,406
Yup, a full head nailer is more readily accepted,one like this.
http://www.harborfreight.com/air-too...ler-69927.html
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Old 02-28-2013, 08:10 PM   #11
Using cliped head nails will not pass inspection in some areas.
There also getting harder to find because of this.
Old 02-28-2013, 08:23 PM   #12
Rewards Points: 528
Joe, I have found that the regular nails work in the clipped head guns.
I had someone give me a bunch and i had a clipped head gun which I tried the in and they worked.
framer52 is offline   Reply With Quote
Old 02-28-2013, 09:35 PM   #13
Rewards Points: 150
Awesome info guys. Thanks for the link to that nail gun as well. So i'm looking for 16d framing nails since I won't be doing much if any toe nailing. Are 10 gauge nails strong enough for framing? Should nail 2 or 3 in per stud?(building the walls laying down then raising up)
Old 02-28-2013, 09:44 PM   #14
Rewards Points: 150
Getting off pkwayyyy
Old 02-28-2013, 09:45 PM   #15
Rewards Points: 150
2x4 2 in top n bottom(if toe nailed 2 in 1 side 1 in other) . 2x6 3 in top n bottom
Tags
framing , nail , nail gun , stud , wall
Me ranting about nails... Pittsville Building & Construction 14 10-05-2012 01:26 PM
Nail gun shock injuries dswan388 Safety 5 06-17-2009 01:21 PM
Nail gun shock injuries dswan388 Roofing/Siding 11 11-24-2008 07:34 PM
Nail gun shock injuries dswan388 Tools 5 11-02-2008 09:46 PM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 09:10 PM
