Choice Of Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 04:59 PM   #1
choice of siding
I am trying to find a material that is not cost prohibited, to make my chimney wall (approximately 300 sq. ft.) look more attractive. Currently,
my home is a gray trim and gray(almost white). I was trying to have a
light and dark gray brick or stone look but the materials were too expensive. Does anyone have any suggestions???
helpneeded4 is offline   Reply With Quote
Old 03-13-2013, 07:52 PM   #2
kwikfishron's Avatar
Rewards Points: 998
Welcome to the forum.
I suggest you start your own new thread and post some pictures.
How can anyone suggest what might look good on your house if we can't see what you're seeing. How to attach a photo to a post
kwikfishron is offline   Reply With Quote
Old 03-13-2013, 11:32 PM   #3
Registered User
Rewards Points: 526
Moved it for you, welcome to the forums!
Gary
Siding right on studs? Davef_dci Carpentry 6 03-07-2013 05:31 PM
caulking butt joints on siding downunder Building & Construction 7 11-13-2008 03:56 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
