Chiseling/Grinding Stone Basement Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 08:49 AM   #1
I need to remove about 1/2 inch from a section of a stone basement wall in order to get a clothes washer down the steps. The wall is made from large stone blocks.
ahileman is offline   Reply With Quote
Old 06-27-2011, 09:07 AM   #2
DIY staff
Rewards Points: 7,174
Picture would help---For a small job an angle grinder with a diamond blade could be used to cut slits so you could knock off chunks.
How about taking the dryer apart and reassembling it in the cellar?
Old 06-27-2011, 07:58 PM   #3
Forget the stone work! As already suggested, take the dryer apart and reassemble in the basement.
vapor barrier on basement pony wall hobbs in vanvouver Building & Construction 3 02-13-2011 08:07 AM
Private Outdoor Courtyard, Wall of Cultured Stone Deeppool Building & Construction 5 12-13-2010 09:56 AM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 12:04 PM
adding rock panels to old stone wall adzling Building & Construction 0 09-27-2010 11:41 AM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
