Old 06-12-2012, 01:18 PM   #1
Chin up bar on a drywall/concrete - good idea?
Hello everyone, I would like to hang a chin up bar in my condo. On one side there is a drywall attached to a concrete wall, however on the other side it is just the drywall. My idea was to hang one side of the bar straight to the concrete wall (through the drywall) with 6 bolts on 10cm square chin-up bar attachment plate that I have made, and on the other side use toggle bolts, again 6 bolts spread on a 10cm square attachment. Will it hold, is it safe? I am 140 pounds but it must be able to hold at least 250 pounds for safety of course.
Thanks for the help
space5555 is offline   Reply With Quote
Old 06-12-2012, 06:47 PM   #2
Can you mount a plate that would go from stud to stud?
mae-ling is offline   Reply With Quote
Old 06-12-2012, 07:13 PM   #3
It sounds very hollow everywhere, I don't know if I will be able to find studs. Is the only way to successfully mount it would be to find a stud? What if I try to mount the chin up bar right beside a door frame with a wall outlet right beneath it? wouldn't it just be naturally more sturdy, as well as a greatest chance of hitting a stud? Also, should not toggle bolts be quite tough and hold around 40 pounds per bolt?
thanks again
Old 06-12-2012, 07:35 PM   #4
I would not expect toggle bolys on drywall to hold 40 lbs, plus that many close together can cause problems
"DIY" - cooking/baking - story rossfingal Off Topic 1157 01-08-2013 12:17 AM
Flatscreen over the fireplace? Is this really a good idea? kashimama Home Theater 43 11-20-2011 12:01 AM
Good idea ???? MR&MRSFIXIT General Discussion 1 02-12-2011 08:34 PM
Sponging Wet sheetrock mud? Good Idea or No? Scotsman General Discussion 5 11-10-2009 03:14 PM
Is using Luan to overlay soffit a good idea? ConstantChange Roofing/Siding 17 10-19-2009 09:48 AM
