Chimney Waterproofing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 05:26 PM   #1
Rewards Points: 20
I am having a chimney company waterproof my chimney. They say they use a water base product.
1. Does the chimney need to be completely dry before applying the product?
2. What is the lowest temperature that you can apply the coating?
3. How long should you allow it to dry before a rain?
Thanks,
Jerry
Jerry8C is offline   Reply With Quote
Old 10-30-2011, 09:47 PM   #2
Rewards Points: 5,336
Chimneys don't need to be waterproofed, they just need to be maintained.
Ron
B. Franklin 1759
Old 10-31-2011, 10:17 AM   #3
Rewards Points: 20
Hello Ron -
When the chimney company was here they put a new mortar crown on. They said the new crown should be sealed with the same waterproofing since it was new. What do you think about the crown?
Thanks for your response.
Jerry
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 07:16 AM
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 07:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 08:00 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
