Chimney Tuckpointing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 11:39 PM   #1
After a period of heavy rains, I noticed my mother's chimney would leak water. The chimney was built in '73, and as you might expect from freeze and thaw, the mortar is cracking. In the mean time, I was going to place a tarp over the chimney and secure it with bungee cords. Would this present any problems? Of course the chimney is not used anymore. When looking at mortar, what would be a good brand?
Yggdrasil is offline   Reply With Quote
Old 09-23-2011, 07:29 AM   #2
If this is a fireplace chimney only, and not for the heater or water heater, covering it will be OK.
Not an expert on cement, but mortar is the usual thing for pointing.
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 07:16 AM
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 07:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 08:00 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
