Chimney Surrounds? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-17-2012, 06:24 PM   #1
Chimney Surrounds?
Any suggestions on pre-fab sourrounds for a chemney?
I will be installing a gas fireplace with B-vent (8")....we already have one fireplace with a real chemney of red brick.
The new chemney is on the second floor at the back of the house....so it only needs to go up a few feet....may or may not be real visible from the street...so...while I would like it to somewhat look like the existing brick chemney....not manditory.
Suggestions? Things to avoid?
jeepdawg is offline   Reply With Quote
Old 08-18-2012, 05:55 AM   #2
Rewards Points: 3,130
While they may exist, I have never seen a premanufactured surround. Perhaps there are too many variables of roof pitch, chimney height, etc. All the surrounds I've seen have been constructed in place.
Old 08-18-2012, 08:35 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
They exist but are like masonite siding and crumble at the slightest hint of moisture.
If the chimney does not go above the roof to much and it is up in the air out of main view then hardie panel will work and paint brick onto it with red brick colored paint and paint the mortar lines in afterwards...
hand drive is offline   Reply With Quote
sterling bathtubs and shower surrounds harson Plumbing 1 04-10-2012 07:08 AM
Tub surrounds Parkeristrouble Plumbing 0 03-25-2012 04:18 PM
Column Base Surrounds mjsarch Carpentry 1 10-13-2011 07:45 AM
Is H20 resistant sheetrock ok behind an f-glass surround? Jeffrey H Plumbing 6 11-01-2010 06:30 PM
Acrylic tub surrounds vs others? Petermgr Plumbing 1 11-08-2008 12:10 PM
