Chimney Stack Removal - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2007, 09:12 PM   #1
chimney stack removal
I am considering removing my chimney stack right through the house. How should I prepare the bare brick walls for plastering after removal? I have heard of instances where soot from the chimney has reacted with the newly put on plaster and made the plaster "bubble up" after it has cured. Is there any special treatment to combat this? Any help greatly appreciated.
davedish is offline   Reply With Quote
Old 02-22-2007, 07:38 PM   #2
How will the appliances be vented?
redline is offline   Reply With Quote
Old 02-22-2007, 08:17 PM   #3
hi, no venting needed,we have adequate central heating in the house.
Old 02-22-2007, 08:26 PM   #4
How is the heating system vented or exhausted?
How is the water heater vented?
Old 02-22-2007, 08:50 PM   #5
heating system/hot water is controlled by a gas combi-boiler in the kitchen which is in turn vented through the wall. This boiler then feeds radiators throughout the house.
Old 02-22-2007, 08:57 PM   #6
Is this a brick house or wood structure?
Old 02-22-2007, 08:59 PM   #7
Brick.
Old 02-22-2007, 09:03 PM   #8
You may want to clean the brick with TSP or other cleaner prior to plaster. It may be in your best interest to seal the brick before the plaster is applied.
If you fur out the area and then install the plaster then that should lessen the condition.
Old 02-22-2007, 09:05 PM   #9
Thanks for the info, will give it a go.
Old 02-22-2007, 09:07 PM   #10
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 05:26 PM
Moisture-proofing chimney box wall penetration faithmyeyes Roofing/Siding 3 01-06-2007 12:23 AM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 01:56 PM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 11:37 PM
