-   -   chimney stack removal (http://www.diychatroom.com/f19/chimney-stack-removal-6638/)
davedish 02-21-2007 09:12 PM
I am considering removing my chimney stack right through the house. How should I prepare the bare brick walls for plastering after removal? I have heard of instances where soot from the chimney has reacted with the newly put on plaster and made the plaster "bubble up" after it has cured. Is there any special treatment to combat this? Any help greatly appreciated.
redline 02-22-2007 07:38 PM
How will the appliances be vented?
davedish 02-22-2007 08:17 PM
hi, no venting needed,we have adequate central heating in the house.
redline 02-22-2007 08:26 PM
How is the heating system vented or exhausted?
How is the water heater vented?
davedish 02-22-2007 08:50 PM
heating system/hot water is controlled by a gas combi-boiler in the kitchen which is in turn vented through the wall. This boiler then feeds radiators throughout the house.
redline 02-22-2007 08:57 PM
Is this a brick house or wood structure?
davedish 02-22-2007 08:59 PM
Brick.
redline 02-22-2007 09:03 PM
You may want to clean the brick with TSP or other cleaner prior to plaster. It may be in your best interest to seal the brick before the plaster is applied.
If you fur out the area and then install the plaster then that should lessen the condition.
davedish 02-22-2007 09:05 PM
Thanks for the info, will give it a go.
redline 02-22-2007 09:07 PM
:thumbup:
