Chimney Separation From House. - Help - Image Attached - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-30-2011, 09:02 AM   #1
Chimney separation from house. - help - image attached
I have attached the image below.
My Chimney which wasn't built at the same time as my house - or doesn't appear to be is separating from my house. I don't use the chimney at all(basement) but was considering putting gas logs in it at some point.
What can I do about the chimney? I thought about having it removed and cap it with cement and put a propane tank on top of the cement but I don't know what something like that would cost and I am on a tight budget at the moment.
Right now its a safety concern for my kids playing in the yard.
Chimney separation from house.  - help - image attached-img_20110807_175533.jpg
mburgess44 is offline   Reply With Quote
Old 08-30-2011, 05:22 PM   #2
Rewards Points: 5,336
It could be strapped to the house. You'd open the wall inside the house on either side of the chimney and install blocking in 2-3 locations(on a 1 story house) up the wall. The iron strapping would wrap the chimney and angle flat on the house brick wall. There would be holes to install carraige through the strapping , the brick wall and the blocking. Install the strapping and slowly tighten the bolts from the bottom up. It will draw the chimney close to the house as you tighten the bolts from bottom to top.
When the bolts are tight, re sheetrock the walls.
The blocking will be inset on the studs so the sheetrock lays flat.
Ron
B. Franklin 1759
Old 08-30-2011, 05:54 PM   #3
kwikfishron's Avatar
Rewards Points: 344
How can you pull it in without addressing the footing? I'd think something’s going to give (break).
kwikfishron is offline   Reply With Quote
Old 08-30-2011, 07:22 PM   #4
Rewards Points: 6,652
The only real way to fix that, is to tear it down and start over again. That is a death trap waiting to fall. Let's hope a straight line wind does not come along.
Old 08-31-2011, 08:52 AM   #5
Rewards Points: 3,130
Have you checked the chimney for plumb? It could be your house that's pulling away.
Old 08-31-2011, 08:41 PM   #6
This repair would be for an improper fastening of the masonry to the house up the face of the structure.
If the footing is the issue, this will only keep the chimney from falling over.
Ron
B. Franklin 1759
Old 09-01-2011, 09:41 AM   #7
Rewards Points: 150
I agree with last post, looks like they didn't use wall ties when they built the chimney or the wall ties have failed, I would check the footing first and if the problem is not in the footing, then Ron's idea should work, short of rebuilding the chimney. Good Luck!
guest is offline   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
Chimney Drafting Seems Un-Solveable dwk02020 HVAC 63 10-17-2012 07:25 PM
shed porch roof attached to gable end of house freemike Roofing/Siding 1 03-28-2010 09:22 AM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 11:43 AM
