Chimney Pipe - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-29-2010, 12:03 AM   #1
chimney pipe
i need instruction to install metal chimney for my stone fire place throgh the wall towards the roof plse
samsara is offline   Reply With Quote
Old 07-30-2010, 12:42 AM   #2
Registered User
Rewards Points: 5,212
Check the manufacturer's web site...
Be safe, Gary
Old 07-30-2010, 06:59 AM   #3
Also check local code. Flue pipe must be isolated from wood where it passes thru walls, it needs a certain pitch, depending on horizontal lengths, material is often dictated by the fuel used, etc.
Old 07-30-2010, 08:35 AM   #4
Rewards Points: 5,336
Why can't you follow the manufacturer's instructions?
Ron
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 11:50 AM
chimney pipe question naehring2000 HVAC 2 03-24-2010 07:29 AM
Heading off roof rafters for chimney pipe. jrcurto Carpentry 4 10-29-2008 01:25 PM
Heading off roof rafters for chimney pipe. jrcurto Roofing/Siding 1 10-28-2008 05:25 PM
