Chimney Crown - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 11:11 AM   #1
Rewards Points: 81
Chimney Crown
What can I use to waterproof a masonry chimney crown for a wood burning fireplace. Can I use standard concrete waterproofing liquid that brushes on, or does the crown require something totally different?
cougar01 is offline   Reply With Quote
Old 10-27-2011, 03:02 PM   #2
mem
Rewards Points: 156
I used Quikrete Concrete Sealer No.8800 on my newly poured and cured crown. It went on rather milky looking but dried absolutely clear. It's been only a few years but still looks new! Got it from one of the from the big box stores.
mem is offline   Reply With Quote
Old 10-27-2011, 10:18 PM   #3
Concrete & Masonry
Rewards Points: 616
If the crown has cracks & other imperfections, it will need more than just a typical sealer.
If it's in good shape,, well it's probably not the cause of any leakage. If you are just wanting to seal it to extend the lifespan of the crown, I'd suggest looking for a penetratign sealer, like a solvent-based siloxane sealer.
jomama45 is online now   Reply With Quote
Old 10-28-2011, 06:29 AM   #4
What the others said, once the sealer is cured, it is not a fire hazard, and it does not really get that hot up there, anyhow.
Water leak around chimney crown. desert-rat Building & Construction 2 12-27-2010 09:49 PM
Installing a new chimney crown ikessky Building & Construction 3 09-12-2010 09:54 PM
Leaking chimney crown DeanPk Building & Construction 2 08-26-2010 08:41 PM
Casting Chimney Crown smitty286 Building & Construction 4 06-18-2008 02:03 PM
chimney crown Halron Roofing/Siding 2 06-15-2007 07:07 AM
