Old 09-23-2007, 08:38 PM   #1
chimney crown
Every post I read says to replace cracked chimney crowns. Can the crown not be repaired? Maybe use a cap that can hold it together after the repair?
kadgar is offline   Reply With Quote
Old 09-23-2007, 09:05 PM   #2
Eibwen
chimney crown
Most crown leaks are around the terra cotta liner and can be filled in with a sealant if its not cracked too bad.
Sammy is offline   Reply With Quote
Old 11-03-2008, 09:06 PM   #3
chimney crown
what can I use to fill the cracks?
zifflerepair is offline   Reply With Quote
Old 11-06-2008, 08:36 PM   #4
chimney crown
Here is a photo of the crack. Is this going to need to be torn down and rebuilt?
Old 11-06-2008, 08:39 PM   #5
chimney crown
Hmm I don't see the picture. I'll try again
Old 11-06-2008, 09:49 PM   #6
chimney crown
Here part of an article from a masonry magazine:
As a general rule, if the building was constructed prior to 1872, it should be repaired with a traditional lime-based mortar consisting only of lime and sand, as well as some color pigment. If the building was built between 1873 and 1932, it should be repaired with a mortar that consists of lime, some Portland cement and sand, as well as some color pigment. This is still considered a traditional lime-based mortar. If the structure was built after 1930, it can be repaired with a modern cement-based mortar, although I personally find that some buildings built up to about 1945 are best repaired with a mix consisting of Portland, lime and sand.
Where do I find such materials? Mine was built in 1907 the mortar looks kind of white.
Here is the link to the magazine: http://www.masonrymagazine.com/6-04/repointing.html
Old 11-08-2008, 09:15 AM   #7
Eibwen
chimney crown
I think thats a little more than some sealant around the liner!
Yes unfortunately that is a rebuild job to me. The brick on the top half have so little mortar that they appear more like dry stacked.
If your not familiar with brick work, you may want to have a pro come in and do a portion of it. Get it inspected by a certified chimney sweep before lighting a fire again.
I would even suggest red tag and flag the area below so people dont get too close underneath. Some of that almost looks like a fall hazard.
Old 11-08-2008, 07:06 PM   #8
chimney crown
That Sir, is a hazardous condition. Get a sweep that does masonry to check that out, and don't even consider building a fire.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 05:26 PM
chimney crown Halron Roofing 2 06-15-2007 08:07 AM
Crown Caulking Not Sure Carpentry 3 08-18-2006 10:40 PM
chimney crown repair. gap between flues andy_b General Discussion 4 02-20-2006 12:22 AM
