Chimney Clearances... Grandfathered Code? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-16-2008, 05:38 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
Chimney clearances... Grandfathered Code?
This might be a question for my building inspector.
I'm opening up the floor plan in my house and now that I've got all the walls open around the chimney I see that the clearances are only about 1.25" at best and zero at worst for the main supporting wall. I believe code calls for 2" around the chimney. Does this need to be corrected or is this considered grandfathered in? I don't know how I could move the wall further away from the chimney anyway. How about if I leave the structure around the chimney as is?
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 03-16-2008, 05:59 PM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
Ask your inspector. Its been my experience that when you open up something that exposes a problem, then that problem must be brought up to code. If the problem is not uncovered, then no. I run into this with plumbing and framing all the time here in VA
USP45 is offline   Reply With Quote
Old 03-16-2008, 06:32 PM   #3
I have gas!
Thanks, I reread the code, it's a little vague but it sounds like I might be OK with a 1" clearance since there is a clay liner. I'll check with the building office anyway to be sure.
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
Moisture-proofing chimney box wall penetration faithmyeyes Roofing/Siding 3 01-05-2007 11:23 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 10:06 AM
