Chimney Caulking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 08:12 AM   #1
Chimney Caulking
We had a new fireplace insert installed a couple years ago and the installer told my wife that we need to caulk the chimney every year. Is this true?
timothyl is offline   Reply With Quote
Old 09-19-2010, 02:54 PM   #2
Rewards Points: 5,336
Chimneys get really warm, especially metal ones. Regular caulking shouldn't be needed on a yearly basis. There might be a high temp caulk put on initially to seal it but it shouldn't need to be redone to often.
Can you post some photos?
Ron
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 06:16 AM
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 06:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 07:00 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
