Chimney - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-28-2011, 06:39 PM   #1
chimney
I have a home in cranford nj which needs to have chimney repaired and bought up to code so it can be sold. do know of any (1 or 2) contractors?
thanks much
adin is offline   Reply With Quote
Old 01-29-2011, 12:04 AM   #2
Registered User
Rewards Points: 5,266
Welcome to the forum!` We are a DIY forum and don't give prices. We can help you do it yourself, though.....
Gary
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 07:16 AM
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 07:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 08:00 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
