Chicken Coop Ridge Beam? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-06-2014, 08:04 PM   #1
Chicken coop ridge beam?
Hello. I live in Hollister, CA. I am going to build a chicken coop that is 20 ft long x 52" wide. It will have 72" wall studs on 24" centers. I was going to use 2x4 rafters (approx 28" length) on a 4/12 pitch with cross joists, but not use a ridge beam. The roof will be 7/16 plywood with asphalt shingles. Is this going to work? Thanks.
hollisterdawg is offline   Reply With Quote
Old 04-06-2014, 08:47 PM   #2
Rewards Points: 3,490
Should work ok.28" is not much of a span. but for the little added cost I would use a 2X4 ridge to tie everything together.20' of 2X4 around here would be around $10
mako1 is offline   Reply With Quote
Old 04-07-2014, 05:52 PM   #3
Mako1, thanks for the reply. 2x4x20' is a good idea. $20 (fir) out here, but dirt cheap for the added integrity.
Triple 2x10 beam has twisted WillK Carpentry 11 12-28-2011 11:50 AM
New ridge beam support needed for cathedral ceiling? zachalyse Building & Construction 12 06-06-2010 07:06 PM
Ridge beam sizing xfloyd Building & Construction 4 05-18-2010 11:08 PM
how do I support a ridge beam with a microlam onyx 1 Building & Construction 8 02-10-2010 08:48 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
