Old 08-10-2011, 04:53 PM   #1
Cheap metal roofing solution?
I'm building a 12x24 barn and got a quote on metal roofing today, which was about $1000. I then realized that metal roofing is not what i had in mind. it is overkill and will probably outlast the barn I'm building.
What material did they use back in the 1940's or so for barn roofs? It looks much more light-weight and thinner:
http://i.imgur.com/zzxcc.jpg
http://i.imgur.com/5mIkt.jpg
Can you still buy that stuff anymore? and what is it called? Thanks
ligyron is offline   Reply With Quote
Old 08-10-2011, 07:22 PM   #2
Corrugated tin.
Master of Cold is offline   Reply With Quote
Old 08-10-2011, 07:28 PM   #3
Civil Engineer
See the Tennessee Williams play "Cat on a Hot Tin Roof" for details and specifications on how to install galvanized steel roofing.
Meridian Metal Roofing Arky217 Roofing 1 12-07-2010 06:33 PM
Metal roofing bronco2 Roofing 17 08-19-2009 09:22 PM
Metal Roofing Brands md2lgyk Roofing 9 01-13-2009 11:06 PM
Cricket Construction on Metal Roofing? Lion Gordon Roofing 1 07-20-2005 10:59 PM
Lathe metal roofing? Stan ETenn Roofing 8 02-18-2005 03:51 PM
