Cheap, Lightweight Wall Ceiling Sheathing For Attic - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 02:31 PM   #1
Cheap, lightweight wall ceiling sheathing for attic
I have a big open attic, I put plywood flooring down and made a huge room. The problem is that it can get very hot and cold up there, and it's also dirty and ugly with the open rafters.
I would like to do a bit of framing and throw up some knee walls on each side and a flat ceiling across the top, then I would like to insulate it.
The problem is the wall sheathing. I only have a pull down ladder to get up there so I can't bring up full sized boards. I also don't feel like bringing up heavy sheetrock and then having to spackle it.
What would you recommend as a lightweight and inexpensive sheathing that I could use? My plan was to just caulk the joints as the boards are being installed, then paint it all.
Phildaglass is offline   Reply With Quote
Old 07-29-2012, 05:36 PM   #2
Rewards Points: 3,130
I have a similar issue, though my attic is much smaller than yours. It isn't even a room, only an 8-ft x 30-ft storage space. And I don't have a pull-down ladder, just a typical 2-foot-square access opening. Since it's in a log house, I've considered tongue-and-groove 1x6, which is what my ceilings are. But that wouldn't be cheap. Another option I guess would be 1/4-inch plywood, ripped down to a size that would fit through the opening.
Old 07-29-2012, 07:05 PM   #3
Rewards Points: 162
Are there any windows in this attic? If not, would you consider adding one? That would take care of the material handling issue. A window on each end would also help give you some cross ventilation. A large room without natural light would feel a little institutional.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 07-29-2012, 08:37 PM   #4
Rewards Points: 149
What exactly are you planning on using the attic for? Sounds like a lot of work for an area that can only be accessed with a pull down ladder.
How did you get the plywood sheets you already put down up there?
LVDIY is offline   Reply With Quote
Temporary brace wall for Cathedral / Vaulted ceiling FCdiy Building & Construction 2 11-04-2011 12:12 AM
Partition wall supporiting ceiling joists (recommendations for removal) afly007 Building & Construction 3 09-29-2011 11:57 AM
Single Pole Switch, but 5 wires in wall and ceiling jmo1112 Electrical 4 10-11-2010 09:51 PM
Exterior Brick Wall with No Sheathing? beesan Building & Construction 1 12-08-2009 06:57 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
