Cheap Fire Place Options? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2012, 01:27 AM   #1
I love my new front yard!
Telfair's Avatar
Rewards Points: 158
Cheap fire place options?
My fire place was listed as unsafe due to voids inside it, ( Cheap/Bad repair job after an Earthquake before we got this house. )
So I've been thinking why cant I just run some metal ducting up the length of the 2 story house to the top of the chimney & mount a small ( Top of stove type hood ) to funnel the smoke from fires into the ducting so I can actually use my fireplace this winter?
I'm gonna be chopping down a tree in my yard that will give me LOT's of fire wood.
Telfair is offline   Reply With Quote
Old 10-21-2012, 01:44 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Bad idea......on so many fronts.....
Just so you know, one can not install a 'new' wood burning fireplace in California....repairing your existing fireplace may be construed as a new fireplace.
The fact that your fireplace is listed as unsafe is a pretty good indication...that it's UNSAFE.
I would look into a gas insert....
Besides....it doesn't get that cold here......we have a fireplace....wood burning....and it's not worth the work to clean it out all the time so we can use it.....as soon as I finish my current project, I will be converting it to gas.
Old 10-21-2012, 02:19 AM   #3
Rewards Points: 2,212
Not sure about the legalities in your area but in some places you can get a wood stove with a chimney liner that fits in a fireplace.
mae-ling is offline   Reply With Quote
Old 10-21-2012, 03:11 AM   #4
Telfair's Avatar
Rewards Points: 158
I already have the Gas insert set up yet while reviewing the inspection video, I'm told its a bad idea?
Maybe, the guy was trying to sell me on him completely tearing down the whole thing & rebuilding it make money?
Thats what I'm asking about!?!?!
Yet it has to be small enough to fit in there?
I dont mind buying a pre-fab kit, its just that I will have so much wood soon & would love to use it.
Not to mention theres something romantic about a fireplace.
Old 10-21-2012, 07:20 AM   #5
Rewards Points: 36
As a side note the tree you take down will not be cured (dry) enough to burn cleanly for several months. It will cause a severe creosote build-up if you get it to burn at all. Yes even one tree depending on the type of wood.
daveb1 is online now   Reply With Quote
Old 10-21-2012, 12:20 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You could try a Wood Stove installation into existing fireplace; Information can be found in the link below, including 6" stainless steel flexible liner pipe and plate at flue location. You will need a chimney cap/cover as well. There are websites that will fabricate both the plate and the cap/cover, if you provide them with the dimensions and details.
(Chimney on my house had no liner - So I did this kind of install myself 5 years ago)
Zero Issues with my install = Burning wood right now as I type this.
(Scroll Down Article): http://www.hearth.com/econtent/index...ng_a_woodstove
- Build Well -
Old 10-21-2012, 12:20 PM   #7
Telfair's Avatar
Rewards Points: 158
Actually I already have wood that been stacked from this tree for about 2 years & will have plenty more after I cut it down.
Thanks for the reminder though.
Old 10-21-2012, 01:13 PM   #8
JOATMON
ddawg16's Avatar
What is unsafe? The actual stack?
Who was the fireplace company?
There is a fireplace business in Gardena that has been around for a long time....family business.....I have never used them but I've heard from many others that they are good.....
I think it's time for a 'second opinion'.
Old 10-21-2012, 08:02 PM   #9
Telfair's Avatar
Rewards Points: 158
2nd Opinion might be a good idea?
Gas Fire Place shawnmurray Appliances 0 12-29-2011 08:47 AM
Older fire place and flues Alex2000 HVAC 1 12-11-2010 04:00 PM
LCD/TV Above Fire Place jfedorek Electrical 2 12-05-2010 05:25 AM
Fire Place / Wood Burning Stove Question fburke Building & Construction 1 12-27-2007 09:52 AM
Laminate Flooring around a brick fire place pamedic13 Flooring 6 11-21-2006 08:42 PM
