Changing Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 01:50 AM   #1
changing stairs
How can I change an existing staircase so the depth of each step is deeper and the angle of the entire stairwell isn't so steep?
doinitourself is offline   Reply With Quote
Old 05-27-2011, 04:26 AM   #2
Rewards Points: 2,240
Welcome to "DIY"!
Some pictures would help.
rossfingal
rossfingal is offline   Reply With Quote
Old 05-27-2011, 06:39 AM   #3
Not a simple task, you have to tear out the old stairs, including the stringers and make new stringers. It may not be practical or even possible depending on space availablilty.
Typical stairs by todays code should total about 18" in rise and run. IRC R311.7.4 deals with treads/risers. Max riser height is 7 3/4", min tread depth is 10". There are other issues such as, available headroom, that might limit what you can do.
The Following User Says Thank You to Just Bill For This Useful Post:
BigJim (05-27-2011)
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 07:16 PM
Help with staining my stairs kimber Flooring 2 12-04-2009 07:45 PM
Strengthening stairs with less support HitLines Remodeling 1 10-29-2009 11:45 PM
Painted the stairs ... . kimber Painting 8 10-07-2009 11:50 AM
