Just curious if anyone has advice on changing a roof type.
I have a regular hip-gable roof on a traditional house. I'm changing my mid-century traditional house to a mid-century modern home. As part of the remodel, I'm changing this typical hip-gabled roof to a butterfly roof.
in doing this, anything I should look out for? I know what is involved but just curious if I've forgotten anything to anticipate before we get to that phase of our project.
Why do you consider it to be so prone to leaks? Because of the valley in the center where the water collects? There will be a rain catchment system that that water will funnel into. Other than that i am not sure why it is more prone to leaks anymore than a typical roof.
With a typical roof system the idea is to shed the roof water away from the house. A butterfly roof sheds the water to the middle of the house.
I’m not saying this will be a problem for you but extra attention needs to be paid to the roofing details. A mistake there could cause you some real problems.
You asked what you should look out for and I’d put that up high on the list.
Butterfly roofs were popular here in Victorian times, but are quite rare now. My daughter has one on her row house, and although it's OK now you can see where it has leaked badly in the past by the staining on the brick party walls in the loft.
A common problem was slight leaks developing in the lead gutters and causing rot in the beams below, which in turn caused the gutter to drop and leak more.
As kwikfishron said the design is taking water to the centre of the building and any slight leak in the gutter will send down a lot of water.
I dont think it will be an issue as long as i use a knowledgable contractor who knows how to seal it properly and drain it adequately. Its perfectly possible to have a butterfly roof without it leaking i am sure it just requires a good design.
I have never seen a Victorian with a butterfly roof. What part of the country are you in? The werent invented until 1933 and are traditionally on mid century or contemporary homes.
I dont think it will be an issue as long as i use a knowledgable contractor who knows how to seal it properly and drain it adequately. Its perfectly possible to have a butterfly roof without it leaking i am sure it just requires a good design. It shouldn't leak when it first done. It's just more of a problem after a number of years.
I have never seen a Victorian with a butterfly roof. What part of the country are you in? The werent invented until 1933 and are traditionally on mid century or contemporary homes. They were around in London a long time before that. http://www.urban75.net/vbulletin/archive/index.php/t-127135.html
I guess you could say some of the older buildings around here have a 'butterfly roof', although the pitch is much lower and certainly not used as a design element.
I agree with others, you're creating a maintenance item with this kind of roof. Still, I'd be interested in seeing the transition, please keep us updated!
Ah, you're in England. They weren't here in the US until 1933.
And I am aware that it would be a few years before it would leak, but my point is that if it is designed correctly there there shouldn't be an issue. Also, the valley is above a part of the house that isn't exposed to furnishings or anything so if it does leak it wouldn't be a huge disaster.
Do you have a plan for how this area of the roof will be ventilated?
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
