Changing Posts And Headers On Existing Patio - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-25-2013, 10:00 PM   #1
Changing Posts and headers on existing patio
I have a patio roof that needs the post and headers replaced. Patio spans 27' and is held up by four 4x6's with three 4x8 headers. My question is this; can I take out two of the columns or just one and split the difference on the headers so as to use only two? Of course I would change the size of the headers and posts. Header would be 6x8 and posts would be 6x6. Is this doable?
tboneshell is offline   Reply With Quote
Old 06-25-2013, 10:09 PM   #2
Rewards Points: 13,450
Got a picture?
I personally would not be using solid lumber for a header, and one that size will sag over that length.
Solid lumber like that is more prone to splitting, curling and twisting.
tboneshell (06-25-2013)
Old 06-25-2013, 10:15 PM   #3
I live in Arizona and that's how it was built with the house. You are correct about the splitting, that's why I am replacing them. So you think I need to just stay with the three headers and four posts? I was thinking about using Douglas fir or a pressure treated.
Old 06-26-2013, 10:25 AM   #4
Old School
Willie T's Avatar
Douglas Fir is good. Pressure treated is pure junk (for the most part) in structural applications. It will warp, twist, check, and split like there is no tomorrow.
Willie T
Patio Structure GeauxCajuns82 Building & Construction 0 06-10-2013 06:59 PM
How to connect deck joists to posts? bryanf Building & Construction 10 04-13-2011 02:07 PM
