Challenge: Build A Wall In Front Of Garage Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-08-2008, 02:42 AM   #1
Question
Challenge: Build a wall in front of Garage door
Hi everyone I'm Pink toolbelt although you can just call me pink. I want to thank you all for this forum because I'm learning a lot. After searching the web, with no luck, I'm turning to you for advice.
Awhile back I had one of our garages (single car) converted into a playroom for my large birds. Yes, birds. The one thing I left alone was the actual garage door which is a standard metal roll up. Now I am preparing to frame it in and drywall. Here's my challenge. The door has those common small windows up top and I do not want to cover those up since the birds love to look out of them.
I am trying to figure out if I can frame from the window down or do I need to do a "standard" ceiling to floor frame with the dry wall framing around the windows. I hope you understand my description. I'm still growing into my toolbelt and have a lot to learn so forgive me if I'm not using the correct terms. My goal is to frame/insulate/drywall but again, my challenge is the window. Any suggestions would be greatly appreciated as well as photos or videos of similar projects since I can follow along.
Again, thank you for all of your expertise here. I know I will learn a lot.
"Pink"
pink toolbelt is offline   Reply With Quote
Old 11-08-2008, 06:01 AM   #2
Whatamess
If your goal is to only frame and insulate the inside then you have the right idea. Frame from the window down and up. When finished top out the wall with a 1X6 sealed against the door for looks and too set plants on or what ever on.
What kind of bird do you have?
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 11-08-2008, 06:27 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
What I have done in the past is to remove the garage door jamb weather striping and install 5/4" x 2" in its place. then screwed the door tight to the strips that i installed outside. removed all lift springs and over head track, then framed my wall. as far as the glass windows the poster above has the right idea. If you have the torsion type of springs leave them and frame over them. BOB
Old 11-12-2008, 02:49 PM   #4
Thank you both for the suggestions. I am going to get started in a few days and will keep you posted. thanks again!
Pink toolbelt
Old 11-12-2008, 03:19 PM   #5
Garage doors and hardware can be sold. If you sold yours, it could off-set the cost of closing in the door.
If heat loss is important a double glazed window could be installed into the standard framed opening!
In good weather, the window could be opened and your bird could get some fresh air!
Help with FRONT DOOR threshold....(pictures) Bobrobert General DIY Discussions 11 11-24-2008 07:32 PM
Raynor Garage Door Opener - Stuck - Please Help! donfan23 General DIY Discussions 2 10-01-2008 08:34 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
Adjusting old garage door springs skeeter_ca General DIY Discussions 9 01-22-2008 07:11 PM
garage door lock jack_j General DIY Discussions 1 12-27-2006 07:40 PM
