Old 08-30-2010, 09:34 PM   #1
ceramic wall tile
Can anyone tell me why I can't use adhesive then grout tile on a painted, panelled wall. I have just the area above the tub/shower unit, going to the ceiing(59"x24"). No water spray or contact to create problems, just want an updated look without tearing out walls and putting up the cement back board.
dogchain888 is offline   Reply With Quote
Old 09-01-2010, 09:32 PM   #2
ceramic wall tile
CBU is a stable surface when subjected to temperature changes and moisture, which important for ceramic tile. You certainly wouldn't be the first person to tile over "whatever is there", and it might work, but you also might have tiles falling off the wall a year from now. I would spend a little extra time and money and do the job right.
cumak is offline   Reply With Quote
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 09:55 AM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
Neophyte to install 2x2 ceramic mosaic wall tile Vickie Tiling, ceramics, marble 3 01-17-2010 06:43 PM
wall shower rack in ceramic tile ProudMarineDad Building & Construction 1 07-05-2009 06:50 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
