Ceramic Tile Walls With Mastic - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 09:13 AM   #1
Lightbulb
ceramic tile walls with mastic
I am replacing the ceramic tile on the walls and the floor. The tile was applied using a mastic adhesive. I have removed the tile from the walls and have tried to remove the mastic on one wall. I finally romoved the mastic from one wall. The walls are sheetrock with a base and finish coat of plaster. I would like to re-tile with ceramic on the walls and floor. Instead of removing the all the mastic, I am wondering whether I can apply a skin coat of thin set plaster such as Durabond 45 or 90 and then apply the wall tiles over the plaster coating. Can I use Weldobond Plus to prepare the walls for better adhesion of the ceramic thinset. I was planning on using Laticrete 4-XLT for the thinset. The floor is on a concrete slab and after removing the tile, I was planning on removing the mastic and using the same Laticrete thinset. Am I doing the right thing here and using the right products Any help would be appreciated.
Also, this is a half bathroom, no bath/shower just toilet and sink. Floor area is 28SF Wall area is 55SF. I know that the smart thing is to rip all the sheet rock out but I want to save all the orignal molding and windows. Thanks for your help
Boris100 is offline   Reply With Quote
Old 02-14-2011, 08:53 AM   #2
Ceramic tile walls with mastic
Any help on this?
Old 02-14-2011, 09:39 AM   #3
DIY staff
Rewards Points: 7,174
You will be just fine with Durrabond to shim coat---
That is not a wet area---any good modified thinset will work---Mike---
Boris100 (02-14-2011)
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 08:50 PM
riddle me this: painting ceramic tile? 99th_Flyby General DIY Discussions 4 06-08-2010 02:33 PM
Mixing Mastic and Thinset in a Tile Job smata67 Building & Construction 2 08-09-2009 10:38 PM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 06:12 PM
