Central Vac Exhaust - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-15-2013, 04:44 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 70
Central vac exhaust
The exhaust for my central vac is just fed into the crawlspace under my garage. Can you think of any reason it would be done this way other than perhaps muffle noise? Is there lot of dust and other debris that can perhaps make it through and shoot out the exhaust? I'm thinking of just cutting it just before it enters as it is in the way for framing. I can always frame around it, but if I don't have to, it will make things easier and also allow to keep the opening big enough. There will probably be a door that goes there.
Old 03-15-2013, 05:44 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
what does the manufacturer recommend?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-15-2013, 07:36 PM   #3
Wire Chewer
Rewards Points: 70
It's from 1982, not much can be found on it. What is typical for these? I'm thinking it's safe to just cut it at the top and then get an elbow and make it point down on the floor, but just want to be sure. It looks like there's a muffler at the vacuum itself too.
Old 03-15-2013, 08:09 PM   #4
Rewards Points: 940
It's nice to get the exhaust out of the house for noise and odor.
I'm not sure how you could have a muffler on it if it goes to the exterior.
You sure can cut it off.
I trust you won't cut off an inlet.
I don't care for the way it drops down and goes back up and out anyway.
cleveman is offline   Reply With Quote
Old 03-15-2013, 08:15 PM   #5
Rewards Points: 704
Dust particles of the filter micron size is what you'll be dealing with and I doubt the central system operation matters where it discharges but if you can tolerate it will be more concern.
When you make the changes abandon those short radius ells if possible and install long radius ( long sweep ) ells for better air flow. If the whole system has the short radius ells let's hope it wasn't installed by a professional.
SeniorSitizen is offline   Reply With Quote
Old 03-15-2013, 08:35 PM   #6
Wire Chewer
Rewards Points: 70
yeah it's all short radius L's as far as I see. I'll go ahead and cut it then and leave it as is. I've been thinking of buying a standard vacuum anyway and this will probably not really be used at that point. I'm actually surprised it still runs! They don't make stuff like they used to.
Old 03-17-2013, 12:38 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,884
That is an understatement.
You probably would have gone through 4 vacuums over the same amount of time in today's "quality".
Old 03-17-2013, 10:40 PM   #8
Rewards Points: 410
Even with a muffler there still is a bit of noise out of them it's just that it's tolerable.
Mine vents into the garage and I've never seen a bit of dust come out of the exhaust.
Here's a web site a friend sent me a while back that they order from and they have a unit of your era.
http://builtinvacuum.com/products.html
High Gear is offline   Reply With Quote
Old 03-17-2013, 10:53 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,122
Well....when you consider that a 'portable' vacuum vents into the room your in......I can't see how it's an issue.
Old 03-21-2013, 02:02 PM   #10
Rewards Points: 16
Central vac muffler
I borrowed a friends idea for a homemade exhaust muffler for my central vac. Without one, it was way too noisy. I then extended it out of the basement side wall, but the noise was embarrasing still. I used some 2 inch plastic plumbing pipe and drilled 1/4 inch holes all over about 2 feet of that pipe. It is a lot of drilling, but it is worth it. I think the holes were about 3/4 in apart all around the 2 feet of pipe. Before assembling the pipe, I slid on some fiberglass pipe insulation (as use on steam pipes). Assemble the balance of your pipes and you will not believe how well it works. My vac is now very very quiet. Almost no cost.
Ray103 is offline   Reply With Quote
Old 03-21-2013, 02:05 PM   #11
JOATMON
ddawg16's Avatar
How about some pics?
Old 03-21-2013, 07:44 PM   #12
Rewards Points: 16
Central Vac Exhaust
Hi again - I took a pic of my vac muffler setup. This is the 1st pic I've ever uploaded, so I hope it comes out.
On the left of the vac is a plastic pipe that is horizontal, then goes verticle. The 2 fatter sections are the pieces of muffler that I described in my previous post. They are nothing more than plastic pipe sections with lots and lots of holes, covered with steam pipe insulation. Works great, and very little noise.
Central Exhaust fan, adding a switch fumbrunner Electrical 2 11-16-2012 01:47 PM
Attempting to wire central exhaust fan to multiple switches ebnub Electrical 18 08-31-2012 11:31 AM
Add Third Timer Switch to Central Exhaust Fan MaxSteel Electrical 4 11-01-2011 03:08 PM
Central Exhaust Relay buzzing Gene Simmons Electrical 7 01-13-2010 05:00 PM
Central exhaust fan SilverBullit Electrical 2 01-10-2010 03:34 PM
