Cementing Fence Posts? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-15-2006, 04:09 PM   #1
cementing fence posts?
When putting up a wooden fence is it necessary to pour cement around the posts?
cambece is offline   Reply With Quote
Old 08-17-2006, 10:22 AM   #2
Contractor
Brickie's Avatar
Rewards Points: 79
Set your fence posts in concrete if you want them to be there permanently.
Here's how you do it:
1. Pound a stake into the ground at each spot where the posts will go. 2. Run a string around the perimeter of your fence line. This will identify potential problems with hedges, trees, and other objects. 3. Cut or buy posts that are 2 feet longer than the finished fence height. 4. Use a posthole auger or digger to make a 2-foot hole at the post site. 5. Put 2 to 3 inches of gravel in the bottom of the hole for drainage. 6. Set the post into the hole. 7. Level the post with a bubble level; anchor the post with stakes and wire or by nailing a couple of 2-by-4s to it. 8. Mix the concrete. Add enough water to make it thick but not chunky. 9. Pour concrete into the hole up to ground level. Poke the air bubbles out of the concrete with a 1-by-2 board. 10. Check the level and adjust the post if necessary. 11. Use a trowel to add some more concrete around the base of the post, making it mound-shaped. This will allow water to run off and not pool around the post.
Brickie is offline   Reply With Quote
Old 09-06-2006, 01:40 PM   #3
Old 09-06-2006, 04:19 PM   #4
Rewards Points: 150
Once you are really good at it you can forgo to the staking/tieing etc of the post, you can just hold it there eye-level while somone pours in the concrete and then put you level on it, if it needs to be adjusted, stick a 2x4 upside it and whack it with a hammer till plump. If your concrete was thick enough it will stay right there.
harleysilo is offline   Reply With Quote
Old 09-06-2006, 10:54 PM   #5
Remodeler
MinConst's Avatar
2' sounds good for southern climates. Up north it would heave in the freeze thaw cycles.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 04:39 PM
Cedar or PT Fence Posts??? C&D Landscaping & Lawn Care 15 04-08-2008 11:27 PM
Fence Posts - Sonotubes? AaronBerquist Building & Construction 20 07-25-2007 12:24 PM
Preferred Fence Wood? Medium_Pimpin' Building & Construction 2 07-06-2007 10:21 AM
Fence problems-Cement or No Cement WBMill Landscaping & Lawn Care 8 06-17-2007 03:36 PM
