Cement Veneer On A Framed Wall (2x4 + OSB) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-27-2011, 03:25 PM   #1
Rewards Points: 1,062
Question
cement veneer on a framed wall (2x4 + OSB)
i want to have an urban art mural, of graffiti if you will, on one of the narrower sides of my 11x9 shed. was thinking to first hang that wire mesh and then smear approximately a half inch layer of some kind of mortar mix to paint on it. i am sure the mix needs to be different than let's say for laying bricks or something, because of the application.
any idea how i should go about this ?
Old 01-27-2011, 05:09 PM   #2
Rewards Points: 5,336
You need to isolate the wood from the masonary product.
Treat the wall like you were putting up stucco.
Ron
Old 01-28-2011, 07:42 AM   #3
Rewards Points: 1,220
2 layers of building paper, lath nailed 6"OC vertically, 16" horizontally, all edges cased. You can then smear regular mortar mix (add fibers if available) on 1/2" thick. Next put on one more thin layer that has the desired texture, I would assume smooth and flat.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
amakarevic (01-28-2011)
Old 01-28-2011, 04:39 PM   #4
Hardee board (cement) siding has 4'x9' panels.
Dwoodsmith is offline   Reply With Quote
The Following User Says Thank You to Dwoodsmith For This Useful Post:
Old 01-28-2011, 04:54 PM   #5
Question
do i still need wire mesh ?
Old 01-28-2011, 04:55 PM   #6
Question
can i still smear a layer over the top of it to smoothen the joints between and the screw holes ?
Old 01-28-2011, 05:20 PM   #7
I don't see why not. It' essentially bare cement. It has a faux siding pattern on the front, but it's flat and a little coarse on the back.
Old 01-28-2011, 05:39 PM   #8
Rewards Points: 582
Use a 4/1/1 sand/lime/cement mix for the base coat and a 5/1/1 mix for the top coat. Use plastering sand rather than building sand.
stuart45 is offline   Reply With Quote
Old 01-29-2011, 07:01 AM   #9
DIY staff
Rewards Points: 7,174
Brick Stain Co--Please go to 'Introductions' and say hello-----you perform an interesting trade,you need to let us know a bit about yourself----Mike-Moderator-
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 10:44 PM
Re-Facing Fireplace Wall with Veneer bamatide Building & Construction 1 06-06-2009 04:14 PM
Patch cement block wall? k.kuenn Building & Construction 4 05-31-2009 08:40 AM
Gluing greenboard to cement wall... tips? AdamB5000 Remodeling 5 03-31-2008 11:11 AM
