Cement Tile Backer Board - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-05-2011, 10:37 PM   #1
cement tile backer board
Can you tell me the "thinnest" thickness of backer board that can be used on a wall for ceramic tile?
Lisarae is offline   Reply With Quote
Old 07-05-2011, 11:02 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Half inch minimum.
XXX
Old 07-06-2011, 08:18 AM   #3
1/2"+ if there is nothing else on the wall(drywall). 1/4 or other wall coverings.
Old 07-06-2011, 10:09 AM   #4
1/2" thick hardiebacker should be the thinnest used on walls
Larry
LPP091155 is offline   Reply With Quote
Old 07-06-2011, 10:32 AM   #5
is this a wet area?
The older I get the better I was
Old 07-06-2011, 06:25 PM   #6
Its one of those, "A friend's friend" is tiling the bathroom. After completing the shower & removing the old tile (installed in the 60's), the existing walls are of course, covered w/the old glue. The "friend" instructed me to (using a chilsel) to remove all the existing old glue and plaster. Basically to take it down to the studded/screened/concrete surface. This seemed pretty excessive, so I thought, "Why can't we cover up the old gunk w/ the same backerboard that was used in the shower? Wouldn't we then have a flat, clean, durable surface in which to lay the tile?" It was pointed out that the backerboard was too thick, therefore the tiles wouldn't butt properly, ie - leaving a larger/fatter/thicker grout line where the shower tile and the wall tile met.
Although I'm extremely grateful for the reduced cost in labor (a friend's friend), it took me nearly 20 minutes to remove a 2" x 3" area. At that rate, it will be 2012 before I get my bathroom finished. I appreciate your input.
Old 07-06-2011, 06:29 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
This is me leaving town.
XXX
Old 07-06-2011, 06:48 PM   #8
Learning by Doing
Leah Frances's Avatar
Bud, you're exiting gracefully it must be really bad.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-06-2011, 07:09 PM   #9
DIY staff
Rewards Points: 7,174
Post a picture---This does not sound like a typical installation.
Old 07-06-2011, 10:27 PM   #10
firehawkmph's Avatar
Rewards Points: 1,868
Hey Bud, try a few of these and it will all seem clearer........
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Bud Cline (07-06-2011)
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 02:46 PM
Backer Board Around Tub Deteriorated devnull88 Building & Construction 3 05-16-2011 09:18 PM
where tile backer meets drywall rtoni Building & Construction 11 01-07-2011 09:05 AM
Hardie backer board DXS General DIY Discussions 2 03-17-2009 05:40 PM
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 10:32 AM
