Cement Slab Touches Buildings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-09-2009, 03:05 PM   #1
Thumbs down
Cement slab touches buildings
The original cement slab was poured about 2 inches from the bottom of the door jam, so the cement actually covers the siding. The 2 adjacent homes are basically connected with the slab. The slabs have moved and there are puddles everytime it rains. We have caulked along side the slab onto the house because some of the siding has gotten wet. This sort of works, looks tacky and could be improved. I just don't know how it could be improved.
One person said to remove some of the cement. Re-pour a new 4" slab and make it so that the water drains to the middle. Is there a better way to redo this whole slab touching-the-siding problem? One end of the slab may be 9" thick and the other end is 9" thick but sits on the cement steps. The slab actually is the top for the steps. Would it be better to remove all cement and use composite decking material? Any suggestions would be great. Thank you.
cbuisman is offline   Reply With Quote
Old 06-09-2009, 04:53 PM   #2
Rewards Points: 1,910
Any chance you can post a photo? This sounds more like a concrete porch. It's not uncommon for concrete porches to settle more near the house producing a slope that drains water to the house instead of away. The reason is because builders are in a hurry and the ground near the house hasn't been compacted and the porch footing doesn't go down to undisturbed earth.
How old is the house and how old is the concrete?
Old 06-09-2009, 10:24 PM   #3
liscenced electrician
Rewards Points: 538
I'm no expert but I'd say to bust it up and redo it with some flashing. Easier to fix now before it starts rotting and you have carpentry items to fix as well
jimmy21 is offline   Reply With Quote
settled cement
xps and t&g on cement slab? HABSFAN2006 Flooring 10 04-14-2009 07:28 PM
upright posts in a wet cement slab shellgirl74 Building & Construction 7 03-19-2009 11:06 AM
Sealing/painting cement slab for humidity? mcu Flooring 2 04-24-2008 09:53 PM
Radiant Heating on Cement Slab can'tdecide Flooring 2 08-21-2007 12:59 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
