Cement Slab Concern - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-01-2011, 01:46 PM   #16
Originally Posted by jomama45 View Post
Then all we can do is speculate. Considering the wood skirt looks OK, I would lean towards a high water table issue, like a blocked draintile, etc...
I understand. I just wish I knew because of mold issues, etc....
dinosaur1 is offline   Reply With Quote
Old 05-20-2011, 04:52 PM   #17
Had a contractor come by today and tell me that they can mudjack the slab for me for $396, is this what I should do?
Old 05-22-2011, 11:28 PM   #18
Concrete & Masonry
Rewards Points: 636
The picture link doesn't work anymore, and my memory sucks, so I don't know what to tell you. If the patio is shedding water to the house, then mudjacking certainly can be a viable option.
jomama45 is online now   Reply With Quote
Old 05-23-2011, 09:20 PM   #19
is it a good idea to have them seal the area after mudjacking? What else should I ask?
Old 05-23-2011, 10:23 PM   #20
Concrete & Masonry
Rewards Points: 636
Sealing the actual concrete surface with a topical sealer? No, won't make a bit of difference.
But if you mean sealing of the control joints, it certainly would be a good idea.
I work closely with a local mudjacker here, and one of the things I'm always impresed about him is that he offers a 5 year warranty on his work. That's certainly something I would ask about.
Old 05-23-2011, 10:31 PM   #21
What do you mean by control joints? Our patio slab is flush against our home so they want us to remove a few pieces of siding. They said they don't caulk, homeowner has to do it. The other thing that concerns is they won't work around my schedule. I told them I want to be there. They said I live far away and when they call they will come on two days if I'm there or not.
Old 05-23-2011, 10:36 PM   #22
Concrete & Masonry
Rewards Points: 636
Control joints are the lines you see placed in the concrete to control random cracking.
It sounds like they want to seal the surface, which, as I said above, won't be helpful at all for your situation.
Sorry, but thats between you and them. Sounds like you need to take 2 days off of work, or just trust they know what they're doing.
Old 05-23-2011, 10:55 PM   #23
To be honest I just won't go with them. What do you mean by control joints?
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 02:46 PM
Putting a gas line in cement slab wskiarea Remodeling 2 03-26-2010 06:59 PM
Cement slab touches buildings cbuisman Building & Construction 2 06-09-2009 10:24 PM
xps and t&g on cement slab? HABSFAN2006 Flooring 10 04-14-2009 07:28 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
