Old 10-28-2007, 04:46 AM   #1
Cement shrinkage
I have poured several slabs of cement using premix that I mixed with my cement mixer. I've noticed that when I am pouring it next to a existing slab that over time the new slab always seem to shrink even though it was level when I finished the job. I'm wondering if the reason is because I did not compact the dirt enough before I poured the slab and that it is just a matter of settling, or if maybe the cement was too wet when I pour it? Any ideas?
sluggermike is offline   Reply With Quote
Old 10-28-2007, 08:06 AM   #2
Cement shrinkage
Its just a property of concrete. It occurs as the concrete cures and does so at an exponentially decreasing rate. You can use type K concrete which is supposed expand if anything but in most cases it just doesnt shrink. Water does increase the inital shrinkage.
ncgrogan is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 01:53 PM
Fence problems-Cement or No Cement WBMill Landscaping & Lawn Care 8 06-17-2007 03:36 PM
HELP! Cement in PVC drain pipe KAT Plumbing 7 05-18-2006 08:17 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
