Cement Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 10:59 PM   #1
Rewards Points: 206
Cement Question
I have a bag of Type S mortar that I bought about 8 or 9 months ago. It was opened and I used some, but it was placed in a trash bag and tied up. I used some today to repair a few rocks that fell off of a natural stone retaining wall and it seems that the cement has lost its bonding ability. Is that possible, does cement lose its properties after a while? Thanks
joeg679 is offline   Reply With Quote
Old 09-23-2010, 06:22 AM   #2
Cement/mortar absorbs moisture from the air and will harden, but if not hard, it has always worked for me. What are you using it for???
Old 09-23-2010, 06:47 AM   #3
joeg. absolutely DO NOT use this bag of cement.
it is junk.
for $4 it's not worth the risk.
i've had to learn this the hard way, having to rebuild a shower curb because of an old bag of mortar.
toss it out.
in the future, any leftover is immediate garbage, in my opinion. sprinkle it in your driveway, dump it in the woods, whatever...
wombosi is offline   Reply With Quote
Old 09-23-2010, 07:18 AM   #4
Rewards Points: 582
What you often find with old cement is that part of it has hydrated but not enough for you to see clearly. It looks OK, but you might have to use 2 or 3 times as much in the mix to allow for the dead cement. If used for anything structural it's not really worth it, but i could be used for something less important such as the infill on a cavity wall foundation.
stuart45 is offline   Reply With Quote
Old 09-23-2010, 07:39 AM   #5
Rewards Points: 206
Ok. Thanks guys
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
Question: custom shower pan (problems) nuklep Plumbing 7 03-22-2010 06:18 AM
Applying texture on smooth cement interior walls Flt_Simulation Remodeling 8 05-14-2009 05:23 PM
broken pipe under cement atichargr Plumbing 5 04-23-2009 11:15 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
