Cement Porch And Step Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-23-2010, 01:20 PM   #1
Cement Porch and Step Repair
Can anyone share some insight on what would be the better approach to repair a porch covered with damaged and missing ceramic tiles.
a) Resurface the Proch and Steps
B) Repair with cement fill, cover the entire porch and steps with 1/2 inch cement layer, then cover with porcelean tile
tennyman is offline   Reply With Quote
Old 04-23-2010, 01:31 PM   #2
Cement porch and step repair
If the remaining tile is in good shape and not falling apart then you can overlay it with a polymer cement overlay and even color and stamp it like stamped concrete.
This overlay only needs to be 3/8 of an inch thick and will be very strong and durable.
If there are more tiles that are loose, they can be removed, do any repairs to the existing stairs and porch with a polymer cement or a product from Rapid Set called Cement All. Then you can re-tile over this material also.
I think the stamped concrete overlay would be a great option if you can find a good installer.
Creteexpert is offline   Reply With Quote
Leveling cement -step down porch with rest of house Cathy2 Flooring 1 05-24-2009 05:15 PM
Pouring a porch up against the house pws Building & Construction 5 09-25-2008 06:52 PM
Building A New Brick Porch Jerry1122 Building & Construction 3 07-10-2008 03:33 PM
Help fixing a concrete step smccull493 Building & Construction 5 07-10-2008 08:01 AM
Sinking Front Porch gpet573 Building & Construction 4 06-02-2008 09:51 PM
